Transition bike
Page 6 sur 7 • Partagez •
Page 6 sur 7 • 1, 2, 3, 4, 5, 6, 7
Re: Transition bike
Oué, ce sont de trèèèès beau vélos.
Il faisait partie de mes coups de coeurs esthétiques, malheureusement c'est monoplateau only (même pas possible de monter un hammer, même si un gars l'avait quand même fait...
Bref, pur freeride, trop exclusif, mais bôôôôôôô
Nombre de messages : 5900
Re: Transition bike
+ 1 mêmes remarques pour ma part. Mono plateau...Breneck a écrit:Oué, ce sont de trèèèès beau vélos.
Il faisait partie de mes coups de coeurs esthétiques, malheureusement c'est monoplateau only (même pas possible de monter un hammer, même si un gars l'avait quand même fait...)
Bref, pur freeride, trop exclusif, mais bôôôôôôô![]()
En deuxième monture lorsque tu peux te le permettre
Nombre de messages : 6379
Re: Transition bike
Popopooo
The 2013 Carbon Covert is Transition Bike’s first carbon frame offering. The 160mm travel Covert was the perfect candidate to bring to carbon as it allowed the bike to shed weight, improve strength, add new features, and update the look at the same time.
“In my mind, this bike really represents the ultimate no holds barred quiver killer. It’s really everything I would want in a single do-everything type of bike and we’ve tried pretty hard to ensure all the right features are there without including things that don’t really matter. A big goal of ours with this project was to develop something with very unique lines that you don’t often see in bicycle frame design…and we feel we’ve really accomplished that. This was a long development effort so we’re pretty pumped to finally unveil our first carbon frame.” Says Kyle Young, Transition Bikes owner.
http://vimeo.com/45041994
Carbon Front Triangle with Carbon Seatstay and Alloy Chainstay and Rocker
160mm Rear Travel
8.5” x 2.5” Fox CTD Adjust Custom Tuned Rear Shock
Optional Fox RC4 Coil Shock Available
All Front Triangle Cable Routing is Internal
Reverb Stealth Seat Post Routing
New Pivot Hardware System
12 x 142mm Dropouts (10 x 135mm Dropouts Sold Separately)
Press Fit 30 Bottom Bracket Shell
Frame Weight 6.75 lbs (Including Rear Shock and Rear Axle)
PRICE: To Be Announced
C.O.C.K & B.A.L.L.S Technology (Only Available From Transition Bikes)
GEOMETRY
Head Tube Angle: 66.5 Degree (Fox 36 160mm) / 67 Degree (Fox 34 160mm)
Chainstay Length: 430mm
Seatube Length: Sm 563, Md 593, Lg 623mm
Reach: Sm 378mm, Md 406mm, Lg 431mm
Wheelbase Length: Sm 1106mm, Md 1137mm, Lg 1169mm
Bottom Bracket Height: 349 mm
160mm Rear Travel
GEOMETRY
Re: Transition bike
Tu débarques !
freeride333- designo-rider
Nombre de messages : 3686
Re: Transition bike
Ah???freeride333 a écrit:Tu débarques !
Nombre de messages : 3910
Re: Transition bike
C'est ça quand tu mets de l'angle dans les virages mecs, je t'apprendrais
Trop vite, trop gonflé, dans un virage, racines/cailloux............bing
Re: Transition bike
Bah je t'apprendrais à mettre la bonne pression pour éviter ça quand tu passeras pas chez moé!Goliath a écrit:C'est ça quand tu mets de l'angle dans les virages mecs, je t'apprendrais![]()
Je rentre vers le 22 sept. Prévu d'aller rouler avec quelques ami(e)s, sauf week end du 27 ou 29
T'es dispo avant que je ne reparte fin octobre?
Re: Transition bike
Pof a écrit:Bah je t'apprendrais à mettre la bonne pression pour éviter ça quand tu passeras pas chez moé!Goliath a écrit:C'est ça quand tu mets de l'angle dans les virages mecs, je t'apprendrais![]()
Trop vite, trop gonflé, dans un virage, racines/cailloux............bing![]()
Je rentre vers le 22 sept. Prévu d'aller rouler avec quelques ami(e)s, sauf week end du 27 ou 29cause course de karting.
T'es dispo avant que je ne reparte fin octobre?![]()
WE du 22 j'emménage avec ma copine, WE du 29 je suis en Ardèche pour un anniversaire. Après c'est open normalement.
T'aurais de quoi concocter que des itinéraires descendants ou aussi avec de la montée ? A ce moment j'emmène quelques furax d'Annecy avec moi
Re: Transition bike
Euh des furax de la montée ou de la descente?
Re: Transition bike
Les 2, héhéhéhéhé
Re: Transition bike
Ah bah vous pouvez toujours partir d'Aime vers la Plagne, mais ça puni un peu...
En général on monte en bagnole jusqu'à la station 1600; 1800..., puis fonction de l'itinéraire on fini de grimper en bike pour tout dévaler jusqu'à Macôt où on laisse un quad ou une autre bagnole pour la récup. Ça fait dans les 300 à 600 de D+ pour 1 000 à 1 400 de D-. Mais ce n'est pas les itinéraires qui manquent.
Ils sont les bienvenus!
Re: Transition bike
Ecoute je leur en parle, mais certains c'est pas 3000 de D+ qui les dérangent
moi non plus, faut juste que je roule, depuis 1 mois et demi j'ai quasiment rien foutu
Re: Transition bike
T'as pas bien lu je crois j'ai dit 3 0 0 m de D+ pas 3000!
Z'êtes cinglé ou bien! T'as vu nos spads?
Re: Transition bike
allez y a pas de raison que mon "pirelli" n'apparaisse pas sur ton topic...
voilà la merveille
On va voir si le modos a assez de "corrones" pour ne pas, encore une fois, bidouiller mon post
voilà la merveille
Nombre de messages : 7676
Re: Transition bike
Dis donc t'aimes ça toi, hein!
En plus tu t'en prends au plus petit de la bande. Huhuhu...
Re: Transition bike
gagné ! le modos n'a pas de "corroners" !
ça va golieth ?
ça va golieth ?
Re: Transition bike
il a dégoupillé...
Nombre de messages : 4390
Re: Transition bike
al1 a écrit:gagné ! le modos n'a pas de "corroners" !![]()
ça va golieth ?![]()
Re: Transition bike
c'est steph en Sm ?
Re: Transition bike
Goliath a écrit:![]()
c'est la nouvelle gamme de sac étanche VERTICAL 8??
Nombre de messages : 3787
Re: Transition bike
Je suis officiellement membre de ce beau topic... pour ne pas dire le plus beau topic du monde
Voila mon petit vélo :
Transition Double
C'est un vélo taillé pour faire tout ce que j'ai pas le droit de faire...
Alors j'annonce :
roues crossmax sx 2012
fourche Rockshox Pike de 100mm (débattement variable de 95 à 140)
amorto fox RP23 de 100mm
anti D e-thirteen
pédalier fsa
selle sdg fly (aïeuuuuuu)
pédales NC-17 SUD Pin III S-Pro (à vos souhaits)
cintre truvavit holzfeller
potence transition
frein avid elixir 5 (de la grosse daube !)
dérailleur xt
voilà pour le principal...
Il est nerveux à souhait et je pense qu'il va vite m’éjecter de la selle le bougre
C'est beau un transition quand même
Pour le fun ça va être super mais pour la rando typée enduro et la DH je risque d'en chi*r !
Transition Double
Alors j'annonce :
anti D e-thirteen
pédalier fsa
potence transition
dérailleur xt
Re: Transition bike
Mais tu fais quoi avec tout ces bikes??? Nomad,transition,pirelli...
En tout cas il est tres beau ce transition
» New year, new bike, my Transition Transam, vive l'endurigide
» Transition Bikes
» Retour sur les Happy Bike Days - Malmedy Belgique
» Transition été/automne : comment se comportent les carnassiers ?
» Run and Bike
» Transition Bikes
» Run and Bike
Page 6 sur 7
